Do Yurts Keep Out Pests?
Old 06-27-2020, 11:38 AM   #1
Question Do yurts keep out pests?
Hello, I'm new here. Trying to buy my first home, and a yurt (from what I know so far) seems to fit my lifestyle the best.
I've been exploring every aspect of yurt life, but one that is important to me is pests. Specifically rodents.
I actually moved out of an apartment after a month simply because it had shrews in it. I'm mortally terrified of rodents.
My Question: Do yurts keep out rodents well? What about bugs? I live in Alaska where shrews are plentiful. I know that I'm going to be purchasing a yurt from Nomad Shelters, sense they seem to be a quality local company.
Thank you!
NamebrandHipster is offline   Reply With Quote
Old 06-27-2020, 10:53 PM   #2
Default Re: Do yurts keep out pests?
Yurts are covered with cloth. I would think a shrew could chew through any wall material if motivated to get inside. Having a cat or dog would possibly alleviate that issue. Good luck.
Old 06-27-2020, 11:46 PM   #3
In Alaska lynx & fox would be an local solution. 😁
Old 06-28-2020, 04:46 PM   #4
I have yet to have a mouse chew through the polyester siding on my Pacific Yurt, but I have had mice inside mostly because I have a plastic water pipe running out the skirt of the yurt. I think they are no more prone to getting rodents than any other structure.
Old 06-28-2020, 09:58 PM   #5
I don't entirely understand how yurts are put together, but mine will be a permanent installation. Are there measures I could take to better seal it?
Such as spray foaming the seam at the base?
YurterRT likes this.
Old 06-29-2020, 08:20 AM   #6
YurterRT's Avatar
I order products from Ace Supply on line for rodent and snake repellants. I put out granules and spray with great results!!
Old 06-29-2020, 08:24 AM   #7
You only would need snakes to clean up with rodents.....
Old 06-30-2020, 12:01 PM   #8
YurterRT's Avatar
and I do let the rat snakes and king snakes thrive
yet no rats so no reason for the copperheads and water moccasins
The granules and spray is good for both snakes and rats to stay clear.
It contains concentrated amounts of peppermint oil and other natural ingredients and seems to work well to repel the unwanted critters. and scents up the place like a newly unwrapped piece of gum - fresher smell ☺
Old 06-29-2020, 09:37 AM   #9
The skirting on most engineered yurts is screwed to the platform. Putting weatherstripping on the skirt before screwing it down tightens it up pretty well. I don't think foam would be any better than that.
Old 06-30-2020, 12:02 AM   #10
I would not use 'Great Stuff' spray foam on yurt fabric. Canned spray foam works great for
and sealing around door and window jams, but sticks like nothing else I have ever seen on site. You would regret it if you had to pull the cover some later date. I have used 'great stuff' insulfoam at work and while it is a fine product, it isn't designed for use on yurt skirting.
nomad shelter yurts
