01-16-2021, 03:36 PM
#5
Re: Solar panel question
Originally Posted by Joycede07
Thanks for the help, Jafo!
The other 4 panels were not wired as you described, but all six are now and things are already looking up.
Thanks again!
No problem. I am glad it is better. I find when you wire it that way, it works better for when one or two panels are shaded, it doesn't drop the performance of the entire array.
When you wire all the panels in series together, then if one panel gets shade, it affects everything (unless you are using micro-inverters on each panel).
Good luck!
