HELP!! Want To Post PY Top Cover To Classifieds... I Can't Get Past Step One.....
Old 05-09-2013, 07:15 PM   #1
Default HELP!! want to post PY top cover to classifieds... I can't get past step one.....
Can anybody help me post to classifieds? I can't get past step one....
Also, I have a
top cover for a 16ft yurt. Any idea what it is worth? It seems to be in pretty good condition. It was built to accomodate 2 french doors. There are no holes in the fabric and the seam all the way around looks good. The only issue is that there are 2-3 spots just over the gutter guard (I think?) where the piece of canvas that was sealed to the room started to pull apart, the areas range in size from less than a dime to a quarter. There is also one spot with a 1-2in tear but it is on the flap of the gutter guard so would not cause a leak.
I've attached photos of the damage. Any ideas on the best way to repair the area where it started to pull apart?
ID:	342   Click image for larger version
ID:	343   Click image for larger version
ID:	344   Click image for larger version
ID:	345   Click image for larger version
tadchipper is offline   Reply With Quote
Old 05-09-2013, 08:11 PM   #2
Default Re: HELP!! want to post PY top cover to classifieds... I can't get past step one.....
Not sure why you cannot get past step one. Are you sure javascript is enabled on your browser?
Old 05-10-2013, 12:09 AM   #3
i don't know what that is... so no i'm not sure
Old 05-10-2013, 02:00 AM   #4
so i googled scripting and it appears to be enabled... the problem is that i go to step one and it asks me what category to post in and then there is no way to move on to anything else.
Old 05-10-2013, 07:05 AM   #5
There should be a button that says GO after you select your category:
Old 05-10-2013, 10:51 AM   #6
well that explains it. i have no GO button.
Old 05-10-2013, 11:16 AM   #7
Which tells me you probably do not have Javascript enabled. What do you get when you go here?
Quick Test: Is JavaScript Enabled?
Old 05-10-2013, 11:32 AM   #8
it says yes. see why m so frustrated? i want the go button!
Old 05-10-2013, 11:33 AM   #9
Are you selecting a category? If so, which one?
Old 05-10-2013, 12:05 PM   #10
I've been selecting Yurt Parts, but I've also tried Yurt Fabric.
pacific yurts
