Yurt And Garage - Conjoined At Birth
Old 09-22-2015, 12:06 PM   #1
Default Yurt and Garage - Conjoined at birth
My wife and I are looking to build a fairly inexpensive living space on the coast of North Carolina here in about 18 months. We like the concept of a yurt but I was also looking for some storage space. The thought process behind this design was that by keeping the kitchen and bathroom in the garage we limit the complexity of the yurt since there's no plumbing and minimal electricity.
Ideally, we'd like to have the yurt and garage open to each other where they are attached. I think the slightly raised yurt would have a cool design effect. You could stand in the kitchen and look into the large expanse of the yurt and it would feel very spacious.
We also figured we would run a standard HVAC system in the house-like parts of the garage and that would provide some space where we would be guaranteed to be comfortable on high heat/high humidity days. This summer was particularly humid where we are moving. Highs in the upper 80s, lows in the lower 70s, and high humidity all day.
I think the "no doors" idea is ultimately not going to work because I suspect the
differences between the yurt and the garage (which will be insulated like a house in the living spaces) will be significant enough that the yurt will cause the HVAC system in the garage to perform poorly.
The yurt and garage will be wooded on 3 sides, meaning they should only see direct sunlight in the middle of the day but my searches regarding yurts and humidity make me question if I shouldn't leave some trees on the front side as well so the canopy provides some additional shade in the middle of the day. I know the trade off here is debris and dirt from the trees and the hazard of trees falling down but I question how comfortable a yurt with no cover will be there.
I thought I would post a link to the plans (it's a PDF) here with the hopes of soliciting feedback. Thank you in advance for your expertise! It has been incredibly educating reading this forum and we likely wouldn't even have considered a yurt without it!
https://drive.google.com/file/d/0B9j...ew?usp=sharing
The yurt in the plan is 30'. We anticipate the bedroom being in the yurt. If we found the humidity was problematic, even after trying other remedies, there is a flex room in the garage that could be turned into a bedroom. If that happened the yurt would be a dining/play/living room type space only.
wrdanner is offline   Reply With Quote
