Question On T&G Flooring
Old 06-23-2015, 11:08 AM   #11
Default Re: question on T&G flooring
Nice platform. Thanks for the pic. If that were my platform I'd install some 2x X bracing between the posts on the down hill side.
Since you are using beams on four foot centers it wouldn't hurt to eyeball the tops for plane from the edge of the platform. I'm thinking you won't need to plane anything unless any individual beam is radically off relative to the others. But you'll need to factor in how flat the overall beam framing is. If there's a big old crown in the top or the top is just simply out of plane somewhat, I'd forget planing and deck it. The tongue on the 2x deck will add massive strength to the floor. 2x6 T&G is absolutely gonna work great for you. Just screw it down well with plated screws.
Couple off topic comments about floor flatness. Fwiw floors need to be really out to feel the variation in flatness. The slab in my basement is all over the map for flatness I know because I built my house and bailed rainwater from the low spots during early house framing. TOOO many times. Lol. All poured residential basement slabs are radically uneven relative to the floor framing above.
Also, century old redos can have floors that are radially out. I've seen two inches in twelve feet redoing kitchen. You CAN feel that, but the occupants are totally used to it. As long as the cabs are plumb and level it really isn't that big a deal. Not an apples to apples comparison but thought I'd toss it in.
As for plastic, go for it. If it rains during decking you'll get to poke some holes.
Old 06-23-2015, 12:03 PM   #12
Thanks for the insight Bob, appreciate it!
I'm excited to get to the flooring step this weekend, hopefully the weather in VT holds out for me.
For
I am planning on only using the yurt on weekends, what would you recommend is the easiest and most affordable
to use and should I install it prior to the flooring?
carbonebria is offline   Reply With Quote
Old 06-23-2015, 01:35 PM   #13
Fiberglass is cheapest, but wheteher it is appropriate for 4' centers is an unknown for me. Perhaps the flanges on 2' wide batts can be stapled to the underside of the flooring? Install the plastic, then the deck, then frpom underneath the insulation? All a guess to me. I've never done it.
I'm sure there is a way to install it so it stays put. Hopefully someone here or a manufacturer that erects their yurts on 4' post and beam platforms will comment. Also another idea is foam sheets come 4' wide and that might be a better option. Screw them to the floor from underneath? I don't know. Insulating wide spans is all guesswork for me. You might research the 'net for ideas in the meantime. Good luck.
Old 06-23-2015, 02:10 PM   #14
Will the sides of the deck remain open?
Old 06-23-2015, 05:34 PM   #15
Yes they will.....I may extend the skirting beyond 8 inches but for the most part they will as I play on using the space under the platform for storage if possible
