04-20-2022, 04:53 PM
#8
Re: My quick intro
Nicely done. That lath looks great! You're gonna have one tough wall. I suggest you coat it with poly, oil or, as I did, paint it with oil base Rustoleum.
Don't use washers. They will rattle when it is windy. I know that from experience.
Leave a small gap between the lattice pieces, or you won't be able to expand it. I know that one from experience as well.
If you end up using carriage bolts, grab the bolt head with pliers to keep it from spinning when you run up the nyloks. With ash lath the square lug under the bolt head just might be held tight enough you don't need pliers. LEAVE A GAP!
Frankly if I made another nomadic yurt I would knot it, like Richard does. Bolts are total overkill on a small yurt. Mongolian yurts were knotted from the gitgo and still are today. Plus you don't need to 'gap' the knots. Good luck.
