Moving Yurt Door
Old 01-08-2019, 01:09 PM   #1
Default Moving yurt door
Hi! I've had a pacific yurt for 3 years now. I have the snow load package with posts for reinforced strength. We love it but want to move the door. We really don't want to take the whole thing down to move the door. Any thoughts?
Thanks!!
Jamie
Jamie Nesbitt is offline   Reply With Quote
Old 01-08-2019, 04:30 PM   #2
Default Re: Moving yurt door
Are you looking to rotate the yurt so the door is facing a different direction, or remove the door from the original location and install it into another one? Also, what diameter yurt is it?
Old 01-08-2019, 09:35 PM   #3
Thanks so much for responding.
Specs: 20' yurt
Door, with window on either side, is currently facing east. Want to move door and window to face north. I don't want to take down the ceiling.
Thanks again.
Old 01-09-2019, 11:15 AM   #4
If you enlist the help of several friends you could disconnect the side cover, door threshold and lattice wall from the platform, and then with several people evenly spaced around the interior perimeter, lift the yurt by gripping the lattice wall and rotate it to face the desired direction. You will of course need to notch the 1" lip of your platform's drip edge where the door will be located to allow the threshold to overhang. Be sure sure re-anchor the yurt onto the platform when you're done. I hope this helps!
Old 01-09-2019, 12:38 PM   #5
That sounds doable. While a 20' yurt is still nomadic in size, with studs under the rafters it's gonna be unwieldy to lift. If you have a man every 6 feet around the perimeter it will take ten guys. With a man every 8 feet of perimeter you'll need 8 guys. Good luck finding that many dudes that can all show up on a Sat or Sunday.
Old 01-09-2019, 12:46 PM   #6
Bob, if that particular yurt has our snow & wind kit, the rafter supports (studs), could be removed prior to lifting the yurt in order to reduce weight.
Jafo, Bob Rowlands and YurterRT like this.
Old 01-09-2019, 02:43 PM   #7
Yeah this sounds like a good plan. I would just be careful you don't slip it off the platform. Don't lift it too high.
Pacific Yurts likes this.
Old 01-09-2019, 04:11 PM   #8
Agreed. They shouldn't need to lift it more than an inch or two.
Old 01-09-2019, 06:38 PM   #9
Pacific, yup good idea.
Old 01-13-2019, 01:51 PM   #10
Thank you all. Hope I have as many friends as I think I do.
cheers,
j
YurterRT likes this.
pacific yurts
