12-28-2020, 12:42 AM
#6
Re: Extractor fan exhaust
Ralex, the downdraft fan units I have seen installed (I haven't installed any myself) are designed to abut the back of a drop in cooktop. Both fit within a standard two foot deep cabinet. To get the powered downdraft appliance into the cabinet behind the cooktop requires both units being designed to work in conjunction, and power in the cabinet so the unit can be switched on as needed. The tinner needs to know EXACTLY where the cooktop cabinet will be placed, so he can stub up his duct during the mechanicals stage of building.
Once the cooktop and downdraft fan unit are installed, a sheet metal connection is made to the exhaust duct that is stubbed up through the bottom of the cabinet. Sometimes that connection is made through the rear of the cabinet into a wall, which is extremely tricky in such a confined space. This kind of stuff gets cussed at, believe me.
Either way, the cooking exhaust exits the home via the floor framing to the side of the home, or into a chase, and then out. For a fact a simple above stove updraft fan unit is WAY simpler. I have installed a few fan units while building the finished decorative surround if it is required that the fan to be installed first.
How this can be done in a yurt with no wall or roof penetration beats me. It either goes through the ring, or through the platform framing.
