Re: Electrical Work Estimates
Three wire Amaralice, make sure your power supply is shut off you have power,ground,neautral, I do not think you will go further than that most fuse box will have a row or two of screws that is for your ground and neutral, or depending on your fuse , you will put hot and ground in the fuse, the one I have only has the hot, but everything I have ran into so far the neutral will be on the box, make sure you have your plug wired right easy enought flip the switch and then run and call the fire department lol no you can do it and it will be fine.
