Building A Yurt
Old 09-04-2014, 07:51 PM   #21
Default Re: Building a Yurt
You're getting there. Making the khana is definitely alot of work. I've built khana for both my yurts. Good job.
Old 09-05-2014, 11:13 AM   #22
Starting Wall 2 now this one is done.
Old 09-06-2014, 03:16 PM   #23
I spent a few hours this morning tying and tying and tying and tying and tying and some more tying. It was worth it since in just about 3 hours I have my 2nd wall just about done. I would have been done but I ran out of slats. Off to Home Depot.
Old 09-06-2014, 03:19 PM   #24
Your khana is growing nicely. Mine is about to be made yet. I plan to go the classic way and use rawhide straps for connecting.
Kevin Nickel likes this.
Old 09-06-2014, 03:30 PM   #25
Can't wait to see some pictures.
Old 09-06-2014, 03:46 PM   #26
I hope to start the khana in a week or two. Right now I'm building the platform under the yurt (see my thread here).
Old 09-07-2014, 12:55 PM   #27
OOOOh Yeah!! The wall is done. I'm building a door frame this afternoon. Then I'll check out how the crown and rafters work. I built a 32 slot wheel when I think I should have built a 36 Slot. I'll see if it will work. If not I have to whip out a new wheel.
Old 09-07-2014, 01:57 PM   #28
Should be fine my 16 footer takes 32. and i just wanted to mention that i use bolts for my wall and i put longer ones around the top to use for coat hangers.
Old 09-08-2014, 09:08 AM   #29
That's a good looking 9 cross yurt khana. Well done.
32 rafters will work fine based on eyeballing the crosses in your photo, and with 2 above the door frame. If not, just skip a rafter cross on the khana in a couple places so they orient straight into the roof ring. Or stuff a couple of yer bowed ones up in there.
Old 09-08-2014, 12:13 PM   #30
Thanks for the encouragement. I tend to worry and over think everything.
Jafo and Knecht like this.
